Brake pedal jumps when almost stopped
JEFF PARKER
  • 2002 CHEVROLET SILVERADO
  • 4.3L
  • 6 CYL
  • 149,000 MILES
The brakes work good until I am almost stopped, then the pedal will jump and I have to stomp on it to stop.
Do you
have the same problem?
Saturday, February 4th, 2017 AT 7:17 AM
HMAC300
  • EXPERT
If you just did a brake job have a mechanic scan for codes for an ABS problem. Then bleed system with his scanner to open ABS valves and get air out.
Saturday, February 4th, 2017 AT 10:53 AM
Recommended Guides
