Brake pedal goes to the floor
JAMES R RADEMACHER
  • 1994 MAZDA 323
  • 1.6L
  • 4 CYL
  • MANUAL
  • 180,000 MILES
I have change the calipers and pads on front and the drums and shoes in back, and bled the system. When I press the brake pedal without the car running it goes about two thirds to the floor, when I start the car with the pedal depressed it goes almost to the floor, when it is pumped it goes to the same position. The car stops but again it goes to the floor. Can you help please?
Do you
have the same problem?
Friday, June 16th, 2017 AT 3:52 PM
  • EXPERT
Are the rear shoes adjusted correctly?
Saturday, June 17th, 2017 AT 3:17 AM
Recommended Guides
