My brake lights not working?
TERRI AND NICK
  • 2004 CHEVROLET SILVERADO
  • 114,000 MILES
Tail brake lights not working but flashers turn signals and third light do work.
Wednesday, April 25th, 2018 AT 4:01 PM
  • 52,797 POSTS
Good morning.
There is a brake light switch on top of the brake pedal under the dash. this is the most likely cause. This guide can help us fix it
https://www.2carpros.com/articles/brake-lights-not-working
Check your fuses as well to be sure there is not a bad one for the brake lights. Check out the diagrams (Below). Please let us know what happens.
Thursday, April 26th, 2018 AT 5:00 AM
CLONE
Electrical problem
2004 Chevy Silverado Two Wheel Drive
my two rear brake lights do not work. The third light up on the cab comes on fine but not the two in the back. I have replaced both the lamps and attemped to see if possibly they might have their own fuses but have not found any thing wrong with any "brake" fuses. Thanks in advance for any help.
Friday, February 26th, 2021 AT 10:06 AM (Merged)
JDL
  • 16,098 POSTS
Welcome, check the stop lamp fuse for voltage, use a testlite on the circuit, if you haven't already. Left instrument panel fuse block, 15 amp. Did you check voltage and ground at the rear?
BENMAN
  • V8
  • 95,000 MILES
Both rear brake lights inop center brake light works fine I have installed new brake light switch and new bulbs still not working
Friday, February 26th, 2021 AT 10:07 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Check fuse on the left side fuse block fuse #4, use only GM approved fuses, some aftermarket fuses can cause issues! also check your email for a pdf if the fuse isn't the problem.
https://www.2carpros.com/forum/automotive_pictures/62217_fuse_panel_int_1.jpg
DBUTTROSS
Both sides brake lights are not working at all. The light above the back window works, however. All of the brake bulbs look good. The LP LIght fuse under the dash and under the hood are both good. Parking/Running lights and blinking lights work.
Did you check the stop fuse see below
https://www.2carpros.com/forum/automotive_pictures/12900_stop_1.jpg
NILSSON6
  • V8
  • 4WD
  • 90,000 MILES
All the brake lights have gone out on our Chevy Silverado. We have replaced the fuses and the brake lights and they still are not working. Is there a switch that was flipped to turn off the brake lights or is this something more serious?
JDL
  • 16,098 POSTS
Hi, any fuses you check, use a testlite on the fuse circuit, to see if circuit is hot? Check the feed to and from the brake lamp switch. Should be close to brake pedal arm. Orange wire is voltage to the brake switch. When the switch is activated by stepping on the brake, the white wire goes hot and carries voltage to brake lites.
RTILEBEINSR
  • 2003 CHEVROLET SILVERADO
  • 6 CYL
  • 80,000 MILES
My brake lights on my 03 chevy silverado does'nt work. But the cab light does. I have checked all bulbs and fuses. I am going to check the brake light switch next but figure out how to get the clip off. Please any information or opinions would be greatly appreciated. Thank You, Rich
  • 108,171 POSTS
If the 3rd light works on the cab, the brake light switch is fine so save your time and trouble. There has to be a break in the wiring. Start at the light socket and follow the wiring until you find power. There are a couple plugs that attach to the wiring harness for the lights. Make sure they are not corroded or damaged.
If the cab light works, the brake light switch is fine. Check for power to the rear sockets as well as the wiring. Check for disconnected or broken grounds. Check for plugs for corrosion and make sure they are tight.
Let me know what you find.
JMALONE
I have been experiencing problems with my rear brake lights. The one on top of the cab works and all the other lights work with the exception of the two rear brake lights. Have checked all bulbs and fuses. Is there a fusable link or something I'm missing?
Friday, February 26th, 2021 AT 10:08 AM (Merged)
MASTERTECHTIM
  • 4,749 POSTS
There are 2 outputs for brake lights from brake light switch. One lights the third brake light. The other feed goes to the turn signal switch then to the rear lights. If your rear turn signals work then your problem is most likely the brake light switch. If not its your turn signal switch.
SERVICE WRITER
  • 9,123 POSTS
The center high mount (3rd) is powered differently and why it is working.
https://www.2carpros.com/forum/automotive_pictures/30961_sil_1.jpg
You can see where the power goes the the 3rd. So appearantly the white has power to the splice at the orange arrow. The blue arrow points to the t/s module.
https://www.2carpros.com/forum/automotive_pictures/30961_sil2_1.jpg
The brake light switch may be bad?
I'm a little weak in the electrical dept. but the module, switch or a wire break would be my thoughts.
DODGER32
  • 2002 CHEVROLET SILVERADO
My brake lights are not lighting up, when I apply brake they wont light up, but they still work when I turn on the blinker
Friday, February 26th, 2021 AT 10:09 AM (Merged)
QUAGMIRE86
  • 98 POSTS
I believe that the brake and T/S bulbs are on two different circuits. It is hard to consider that both your brake bulbs would go at the same time along with your center high mount lamp too. So, start simple and check the fuse. Then check the brake light switch that is attached to the brake pedal. Look it over to make sure the plastic switch body is still intact and properly affixed to the brake pedal. The last thing (and most frustrating) could be a short circuit in the wiring. All you can do is test the wiring from source to end to try to locate the short or bad ground. Good luck.
PLUMBING
  • 187,000 MILES
I have changed the bulbs and brake light switch and brake lights not working.
  • 108,171 POSTS
Based on what you replaced, I have to ask, did you check for a blown fuse? If not, check fuse 14 in the under hood fuse block. I have attached a picture of the fuse block which includes a legend of what each fuse is used for.
Also, here are a few links which discuss fuses, how to replace, how to use a test light, and how to check wiring. I included them because if the fuse is good, I need you to confirm there is power to and from the fuse.
I hope this helps. Let me know if you have questions or need more information.
PGARCIA661
  • 6 CYL
  • MANUAL
  • 92,000 MILES
The brake light on the bed of the truck are not working. The brake light on the cab does. I've changed the bulbs check the wires bulbs didn't work not sure what to do now. Also fuses are good.
Check and test the rear lamps junction block front of rear bumper on crossmember light blue wire for power if its not there you have an open wire between this point and the vehicle stop fuse 10amp
this guide will help you
