Cigarette lighter fuse and wiring diagram
WKBFNB
  • 2005 BUICK LESABRE
  • 6 CYL
  • FWD
  • 26,000 MILES
Cigarette lighter and auxiliary power fuses have both been replaced with new fuses, but neither plug has power. #65 is empty, too. There are a surprising number of empty slots. I mapped those that are filled, if that helps with the diagnosis.
My model does not have anything in the Cigar. Mini Relay slot. Do you have any other diagnosis suggestions for this issue? Yes, I looked under the left rear seat and found that position #58 is empty. I acquired the car 6 month ago. The cigar. And aux. Power worked until last week. Thanks.
Tuesday, February 22nd, 2011 AT 5:12 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,840 POSTS
There is a relay and a fuse to power the cigarette lighter, use a test light to see where you lose the power at. Here is the wiring diagram and a guide to help you test for the problem and some diagrams (below)
and
Tuesday, April 18th, 2017 AT 3:34 PM
See pictures for location:
Tuesday, April 18th, 2017 AT 3:35 PM (Merged)
REDMA
  • 2003 BUICK LESABRE
  • 6 CYL
  • FWD
  • 90,000 MILES
Electrical problem
2003 Buick Lesabre 6 cyl Front Wheel Drive Automatic 90000 miles
The cigarette lighter works intermittently - and we need it to power accessories such as the Ipod - I have checked the fuses which are fine
DAVE H
  • 13,383 POSTS
There is probably a bad wiring connection. Posibly behind lighter housing.
ALEXSTUR
  • V6
  • 162,000 MILES
I have replaced the fuse for my cigarette lighter (#23 on the fuse box) but only one of them actually worked. I want to know how I can fix the other one and if there is another fuse for the other cigarette lighter?
Thursday, September 17th, 2020 AT 12:54 PM (Merged)
STEVE W.
  • 12,950 POSTS
Fuse 22 powers the auxiliary power outlets, fuse 23 is the actual cigarette lighter. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
2CP-ARCHIVES
  • 4,542 POSTS
  • 2000 BUICK LESABRE
  • 120,000 MILES
How do I get power back into the cigarette lighter? Also how the gas gage doesn't work. Help
Friday, April 2nd, 2021 AT 10:34 AM (Merged)
JDL
  • 16,098 POSTS
There is usually a cigar fuse. Maybe the heating element is faulty? As far as the fuel gage, could be issue with sending unit--wiring circuit--or instrument cluster. Give me a second to find wiring diagrams.
JDL
  • 16,098 POSTS
Yes, check the cigar lighter fuse, also, check for voltage at the fuse circuit, hot all the time.
