Bolts seem to be bent on transmission pan
REGGIE777
  • 1997 FORD WINDSTAR
  • 153,000 MILES
I believe I bent my the bolts on my transmission pan when I went over what appear to be some bricks. It has been leaking alot since then. The bolts look like they are bent. Should I replace the bolts with some new ones or what.
Do you
have the same problem?
Friday, July 19th, 2013 AT 9:09 AM
HMAC300
  • EXPERT
Checkfor a cracked case if the bolts bent
Friday, July 19th, 2013 AT 9:33 AM
Recommended Guides
