Need fan belt routing
MIKE LOPES
  • 2000 BMW 528
  • 6 CYL
  • MANUAL
  • 97,000 MILES
Need fan belt routing?
Do you
have the same problem?
Monday, April 28th, 2008 AT 7:11 AM
See below
https://www.2carpros.com/forum/automotive_pictures/12900_belt1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_belt2_1.jpg
Thanks to Rasmataz from Dr. Hagerty
Monday, April 28th, 2008 AT 7:23 AM
ANDREMCGAUGHEY
  • 1999 BMW 528
  • 6 CYL
  • 11,500 MILES
What is the route of the belts when replacing them: Which one goes on first?
Wednesday, May 20th, 2020 AT 1:35 PM (Merged)
DOCHAGERTY
  • 9,601 POSTS
The A/C belt goes on first and then the water pump/power steering pump/alternator belt. The route is obvious for the A/C. The water pump, alt, P/S belt, starting at the top pulley for the water pump, go under the deflection pulley then over the alt. Then around the P/S pump then around the crankshaft and then to the idler pulley and then to the water pump and that is it.
FLYIII
  • 1998 BMW 528
  • 6 CYL
  • 56,000 MILES
I need thw serpentine belt diagram for my car 1998 528i
DOCHAGERTY
  • 9,601 POSTS
I can describe the routing for you. Starting with the water pump pulley, off the top of that, then it goes under the deflection pulley, over the alternator, down to the power steering pump, along the bottom to the crankshaft pulley, around the tensioner pulley and to then back to the water pump.
FLYIII
  • 1998 BMW 528
1998 BMW 528 Engine Size unknown Four Wheel Drive Automatic 56000 miles
I need the serpetine belt diagram for my 1998 528i please
FLYIII
2CP-ARCHIVES
  • 4,544 POSTS
  • 1997 BMW 528
I need the belt routing diagram for a 1997 528i with a tension pulley.
SATURNTECH9
  • 30,870 POSTS
See if one of the diagrams I posted is what you have.
DOCHAGERTY
  • 9,601 POSTS
Is there anything else you need?
SCJTOWING
  • 1997 BMW 528
Need fan belt routing for 1997 BMW 528i
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_bmw_1.jpg
:wink:
