1997 BMW 528 cooling problem
JOE1998
  • 1997 BMW 528
  • 6 CYL
  • 140,000 MILES
Yesterday, was driving on freeway and the car just started getting hot to the red, I checked the coolant level it was good, then I checked the fan, which it only has one (no condensor fan) and it wasn't turning on when the temp rose. I then turned the ac on and the fan clicked on, so what should I do, Is it the fan switch or the thermostat, or? Also the heater doesn't blow warm anymore, just cool?
Do you
have the same problem?
Tuesday, February 5th, 2008 AT 12:43 AM
  • EXPERT
Replace the thermostat
ELECTRIC COOLING FAN PROBLEMS
A fan failure, or a failure of the fan relay or control circuit is bad news because it can allow the engine to overheat.
Five things may prevent an electric cooling fan from coming on:
Defective temperature switch or coolant sensor Engine thermostat is stuck OPEN (engine never gets hot enough to turn on the fan)
Failed fan relay
A wiring problem (blown fuse, loose or corroded connector, shorts, opens, etc.)
Bad fan motor
Tuesday, February 5th, 2008 AT 4:18 AM
