2001 BMW 330 ECM
JUSTICE04
  • 2001 BMW 330
  • 6 CYL
  • 120,555 MILES
My turn signals blink on the outside sometimes on the dash. AC blows up & down never constant. Pass mirror does not work on same problem. Also no rear defrost. Everything works together or not at all. Had it checked for loose wires none found. He thinks ECM rec. Bring to dealer LOL do you have any ideas for testing prob. Or get loan an bring to stealer oops I mean dealer THANKS
Do you
have the same problem?
Tuesday, June 29th, 2010 AT 9:01 AM
DR. HAGERTY
The turn signal issue might be the rear lamp holders, check the brown wire for heat/corrosion. The A/C issue is the final stage unit, check this link: http://www.realoem.com/bmw/showparts.do?model=BN53&mospid=47713&btnr=64_0820&hg=64&fg=40
No defrost could be no power or a bad grid, turn it on and attach a meter to the electrical leads at the sides. Right mirror may need a new motor if it is totally dead.
Tuesday, June 29th, 2010 AT 8:45 PM
Recommended Guides
