2004 BMW 325 Battery
MJT3
  • 2004 BMW 325
  • 6 CYL
  • AWD
  • 92,000 MILES
I have a 2004 BMW 325i. I recently changed the battery (purchased at Auto Zone $140.00). There is power to the vehicle (lights come on, etc); however, the engine only turns over - will not start.
Do you
have the same problem?
Sunday, August 22nd, 2010 AT 5:48 PM
DR. HAGERTY
There may be an unrelated failure of the fuel pump. Crank no start is usually caused by something like a failed pump. Try taking up the rear seat bottom, the pump is accessed through the port on the right side. Get a mallet and beat on the top of the tank, if it starts, replace the pump. check this link: http://www.realoem.com/bmw/showparts.do?model=AN37&mospid=47720&btnr=16_0373&hg=16&fg=15
Monday, August 23rd, 2010 AT 7:38 AM
Recommended Guides
