2003 BMW 325 Got car inspected, now no sound from radio
VIOLINS3
  • 2003 BMW 325
  • 6 CYL
  • FWD
  • 45,000 MILES
I took my car in for inspection yesterday. Radio worked fine. When I turned on the car to leave, the sound system no longer worked. All the lights come on, you can see the stations, but no sound, including when I put in a cd. Any ideas? Could they have knocked a wire loose or set off some kind of anti-theft trigger? Thank you!
Do you
have the same problem?
Friday, July 2nd, 2010 AT 3:20 PM
CARADIODOC
  • EXPERT
Hi violins3. Welcome to the forum. What kind of inspection? Exhaust? Steering and suspension? Brakes? Emissions? Did any work done require disconnecting the battery? If so, suspect a fuse blew due to normal current surges when the many computer memory circuits charge up when the battery is reconnected. Look for a fuse for a remote-mounted amplifier.
Caradiodoc
Friday, July 2nd, 2010 AT 3:37 PM
Recommended Guides
