BMW E36 318 iS trouble with ignition start
TONY_BG
  • 1936 BMW 318
So i've had this awful problem which I can't find a solution. Here 's the situation- when the car heats up (when i've been driving for 30min.) If I stop and turn off the ignition it won't start again until it cools down. When I try to turn the key it starts and cant hold the needed revs and it stops. If I try to give it a little gas it again stops!Otherwise I can drive all day but can't turn it off, because it wont' start for at least half hour until it cools down. Please help me, I 've changed the camshaft sensor(or smth like that, which I was told was the problem - IT's not it ! )
Do you
have the same problem?
Friday, August 18th, 2006 AT 10:34 AM
JACK42
Ignition module or crank sensor
Tuesday, September 12th, 2006 AT 12:27 PM
Recommended Guides
