Blinker
ROBIN STERLING HOWARD
  • 2011 FORD F-150
  • V8
  • 4WD
  • 132,000 MILES
The deal you push up or down to turn your signals on is on left side of steering wheel also operates windshield wipers, will not stay where it should. I have to hold down on it to keep right turn signal off and when I push down left turn signal does not come on at all, if I just let go of it it goes in position for right turn signal an stays there.
Do you
have the same problem?
Monday, June 5th, 2017 AT 6:42 AM
HMAC300
  • EXPERT
That is the multi function switch which may be the problem of not turn signal. Normally these have to be replaced when like that. You can have a mechanic check it as the air bag has to come off and best done by a mechanic.
Monday, June 5th, 2017 AT 8:16 AM
Okay! Thank you very much I will call a mechanic.
Monday, June 5th, 2017 AT 8:20 AM
KEN
  • ADMIN
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
Wednesday, June 7th, 2017 AT 9:26 AM
Recommended Guides
