Bleeding the FRONT BRAKES
BRITTNEY IANNIELLO
  • 2006 CHEVROLET SILVERADO
  • 5.6L
  • 4WD
  • 180,000 MILES
Changed the calipar on front driver side and brake pad and shoes and rotar. On front passenger just pads were replaced. Is there a special way to just bleed the front brakes?
Do you
have the same problem?
Sunday, April 15th, 2018 AT 4:52 PM
  • EXPERT
Good morning.
No, but if got air into the system and it got to the ABS, then you need a scan tool to bleed the ABS system. You cannot manually bleed the ABS.
Have you tried bleeding the system yet?
Monday, April 16th, 2018 AT 4:44 AM
Recommended Guides
