Battery light and awd disable light comes on at same time.
1STPLACE
  • 2006 BUICK RENDEZVOUS
  • 3.5L
  • 6 CYL
  • AWD
  • 115,000 MILES
Battery light and AWD disable light comes on between 45 to 60 mph and the engine loses power when it takes place wont do it every time and I have also noticed when turning sharp left or right makes a noise in the rear end not sure if this is related with each other or not have already installed new alternator and changed differential fluids noise in rear end went away temporally and then returned
Do you
have the same problem?
Thursday, May 21st, 2015 AT 7:42 AM
DOCFIXIT
  • EXPERT
Check engine light on? If yes what is Code
Thursday, May 21st, 2015 AT 8:08 AM
Recommended Guides
