Battery light
DARLENE CHU TRIBLETT
  • 2004 BUICK RENDEZVOUS
  • 3.4L
  • 6 CYL
  • 4WD
  • 16,584 MILES
My battery light keeps coming on the alternator and battery are good.
Do you
have the same problem?
Wednesday, March 1st, 2017 AT 2:41 PM
CARADIODOC
  • EXPERT
How was the charging system tested, and what were the results? This problem is acting up intermittently. Was the testing done while the problem was occurring?
Wednesday, March 1st, 2017 AT 3:04 PM
Yes could not find anything out. My harness that plug's into the back of the alternator only has one wire do not know why.
Wednesday, March 1st, 2017 AT 8:52 PM
Yes couldn't find anything out my harness that plug's into the back of the alternator only has one wire don't know why
It was tested with some type of battery charger and a electric tester by a mechanica I know.
Wednesday, March 1st, 2017 AT 8:56 PM
CARADIODOC
  • EXPERT
There's a lot more involved with this type of problem. Most simple testers only check that the battery voltage is between 13.75 and 14.75 volts with the engine running. You can do that yourself with an inexpensive digital voltmeter. If that voltage is okay, that only means it is okay to perform the rest of the tests, but you need a professional load tester for that. Specifically, we need to know "full-load output current" and "ripple voltage".
All AC generators have at lest six diodes, and if one fails, all you'll be able to get is exactly one third of the rated output current. 30 amps from the common 90-amp generator is not enough to run the entire electrical system under all conditions. The voltage regulator will detect that missing one third of the output and turn on the "Battery" warning light in response.
If it is necessary to replace the generator, also look at the age of the battery. Due to the design, these generators develop a lot of harmful voltage spikes that can damage those diodes, and the internal voltage regulator, and they can interfere with computer sensor signals. The battery is the key component in damping and absorbing those spikes, but as they age and the lead flakes off the plates, they lose their ability to do that. It is common to go through four to six replacement generators in the life of the vehicle. To reduce the high number of repeat failures, always replace the battery at the same time, unless it is less than about two years old. If it tests good, it can still be used in an '86 or older GM car with the older generator design.
Thursday, March 2nd, 2017 AT 7:07 PM
Thanks will try
Friday, March 3rd, 2017 AT 9:07 AM
Recommended Guides
