Tools Required
J 38778 Trim Pad and Garnish Clip Remover
Removal Procedure
Remove the inside door handle bezel.
Remove the power accessory switch mounting panel, if equipped with power accessories.
Remove the trim panel armrest screws.
Use the J 38778 in order to release the door trim panel retainers.
Remove the door trim panel from the door.
SPONSORED LINKS
Sunday, July 5th, 2009 AT 6:01 AM
