Bad compressor
SYEKEYE
  • 2000 FORD TAURUS
  • 3.0L
  • 177,234 MILES
My ac compressor locked up and caused my belt to break. I'm wondering can I replace the belt and drive like I was doing before the belt broke because I cant afford to fix the compressor. Or can I just bypass the compressor and add a shorter belt
Do you
have the same problem?
Tuesday, January 19th, 2016 AT 10:00 AM
HMAC300
  • EXPERT
If you replace the belt check first if it will spin on compressor if it does then disconnect the electrical on the compressor or it will break the new belt as well. You should replace tensioner at same time. It it doesn't spin on compressor then you need to go to auto parts to find something that will work, you may need a pulley as well for this.
Tuesday, January 19th, 2016 AT 10:38 AM
Recommended Guides
