Backfire then stalls
RGMAINTENANCE66
  • 1994 CHEVROLET MALIBU
  • 5.7L
  • V8
  • 140,000 MILES
My engine will accelerate and then after about two minutes it backfires through the carburetor cuts off and starts right back and idles fine. I bought a new carburetor, a new distributor, a new fuel pump and I adjusted all the rockers half a turn from point of no play on my roller rockers my engine temp at idle is 140, my timing is at 8 degrees BTC. No problem starting, but it back fires really hard and cuts off
Do you
have the same problem?
Friday, June 17th, 2016 AT 7:12 AM
KEN
  • ADMIN
Hey,
Its sounds like you might have the wrong spark plugs installed and they are to cold, can you double check this please?
The only other reason the engine would do this is a lean backfire. The rebuild carburetor will be lean because that's the way the government makes them do it.
Maybe you should get the old one rebuilt or take it part and do it yourself
Let me know what you find
Best, Ken
Saturday, June 18th, 2016 AT 9:54 AM
Recommended Guides
