1998 Audi A6 Ongoing cooling problem
LARRY1669
  • 1998 AUDI A6
  • 6 CYL
  • AWD
  • 91,000 MILES
I just replace the fan clutch 3 weekls ago and car still runs very warm. I noticed the fan was engaging a week ago but is no longer working. What is the cause of a fan clutch failure?
Do you
have the same problem?
Friday, July 25th, 2008 AT 5:51 PM
KHLOW2008
  • EXPERT
Hi Larry1669,
The clutch fan operates on both heat and silicone oils to keep it up to speed. Even if there is no oil, it would still operate, but with not much force.
If it is the electrical fan, it would not operate unless the AC is turned on with compressor working or when the fan switch heats up.
What temp is the gauge registering?
Any coolant shortage?
Friday, August 1st, 2008 AT 2:30 AM
Recommended Guides
