Anti-theft system reset
EVELYN VICK
  • 2004 FORD F-150
  • 4.2L
  • V6
  • 185,000 MILES
Replaced PCM, fuel pump, and fuses. Thought this was my problem. Truck anti theft system has been flashing fast so trying to reset it. No luck so far please advise.
Do you
have the same problem?
Saturday, December 9th, 2017 AT 11:03 AM
PATENTED_REPAIR_PRO
  • EXPERT
If trying a spare key did not work, and getting a new key cut is not something you can or want to do then it appears you are going to have to have the trouble codes retrieved to find out why the security light is on.
Saturday, December 9th, 2017 AT 12:06 PM
EVELYN VICK
It says PAT's is engaged. Rubber ring around ignition switch is not reading key to reset PAT's.
Saturday, December 9th, 2017 AT 4:47 PM
PATENTED_REPAIR_PRO
  • EXPERT
What says that? The instrument cluster, a scan tool, what?
Saturday, December 9th, 2017 AT 5:08 PM
EVELYN VICK
Theft light flashes once and pauses and flashes six times and pauses. Then repeats over and over indicating code16. Please help.
Saturday, December 9th, 2017 AT 5:12 PM
PATENTED_REPAIR_PRO
  • EXPERT
I was not aware the theft light showed trouble codes in that manner. Maybe someone else on here know, but I do not.
Saturday, December 9th, 2017 AT 5:34 PM
EVELYN VICK
Okay, and thanks for reply.
Saturday, December 9th, 2017 AT 5:39 PM
KEN
  • ADMIN
It definitely sounds like you have a programming issue. I do not know about the code flashing first time for me as well. I learn something almost everyday here. Here are the instructions from ford on the troubleshooting and programming methods:
Key Programming Using Two Programmed Keys
NOTE:
This procedure only works if two or more programmed ignition keys are available and it is desired to program additional key(s). If two keys are not available, refer to KEY PROGRAMMING USING DIAGNOSTIC EQUIPMENT.
NOTE:
PID SPARE_KY must be enabled for this procedure to operate. If this PID is not enabled, follow the security access procedure. Refer to ANTI-THEFT SECURITY ACCESS and select SPARE KEY PROGRAMMING SWITCH: ENABLED.
NOTE:
If the programming procedure is successful, the new key(s) will start the vehicle and the THEFT indicator will illuminate for approximately three seconds.
NOTE:
If the programming procedure is not successful, the new key(s) will not start the vehicle and the THEFT indicator will flash. If the programming procedure was not successful, repeat the key programming procedure from Step 1. If the failure repeats, refer to DIAGNOSIS AND TESTING to review the DTCs and carry out the pinpoint tests as necessary.
NOTE:
A maximum of eight ignition keys can be programmed to a passive anti-theft system (PATS) equipped vehicle. If more are needed, refer to KEY PROGRAMMING SWITCH STATE CONTROL.
NOTE:
If the steps are not carried out as described, the programming procedure will end.
NOTE:
Ignition keys must have correct mechanical key cut for the vehicle and must be a PATS encoded key.
NOTE:
If the vehicle is in unlimited key mode, this spare programming procedure still functions. Any two keys that can start the vehicle may be used to program in an additional unlimited key.
Insert the first programmed ignition key into the ignition and turn the ignition from OFF to ON (maintain the ignition in ON for one second).
Turn the ignition OFF and remove the first key from the ignition lock cylinder.
Within 10 seconds of turning the ignition OFF, insert the second programmed ignition key into the ignition and turn the ignition from OFF to ON (maintain the ignition in ON for one second).
Turn the ignition OFF and remove the second key from the ignition lock cylinder.
Within 20 seconds of turning the ignition to OFF, insert the unprogrammed ignition key (new key) into the ignition and turn the ignition from OFF to START (attempt to start the vehicle).
If it is desired to program additional key(s), repeat the key programming procedure from the beginning.
Key Programming Using Diagnostic Equipment
Turn the ignition from OFF to ON.
Using the diagnostic tool, follow the SECURITY ACCESS to obtain security access. Refer to ANTI-THEFT SECURITY ACCESS.
From the diagnostic tool menu, select IGNITION KEY CODE ERASE.
Do not select any additional commands from this menu.
Turn the ignition OFF and disconnect the diagnostic tool.
Insert the first encoded key into the ignition and turn the ignition ON for one second.
Insert the second encoded key into the ignition and turn the ignition ON for one second.
Remove the second encoded key from the ignition.
The vehicle should now start with both ignition keys.
Have you tried a hard reboot of the system by holding the negative battery cable to the positive post discharging the capacitors and then reconnect and unlock the drives door.
Check out the diagrams (below).
Cheers, Ken
Monday, December 11th, 2017 AT 5:45 PM
