Transmission problem
1993 Other AMC Models 4 cyl Two Wheel Drive Automatic
hello i have a vehicle 1993 plymouth acclaim 4 cylinder yesterday i changed all the transmission i also changed the gasket and also the filter and i added new fluid the new fluid is was red so i took it for a test drive to see if it was good so i checked the fluid again after driving it the fluid went from red to brown again so is this normal considering maybe the old fluis is still in there it needs time to run out before the new fliud can become red again
Mar 24, 2009 at 7:11 AM
