Drive belt diagrams please?
RICHO
  • 2005 HOLDEN RODEO
  • 4 CYL
  • MANUAL
  • 101,100 MILES
Holden Rodeo 2005, I've changed all fan belts but the squeal has come back after 1 month. Which pulley do you recommend would be the offending one to change?
Wednesday, March 16th, 2011 AT 6:44 AM
  • 31,938 POSTS
Remove one belt at a time to see if that will isolate the noisy pulley, also new belts do streach, just check the adjustments first. Here is the belt diagram you requested
https://www.2carpros.com/diagrams/isuzu/rodeo/2004
Wednesday, March 16th, 2011 AT 6:53 AM
JAMES CAMERON MITCHELL
  • 2004 HOLDEN RODEO
  • 3.0L
  • 4 CYL
  • TURBO
  • 4WD
  • MANUAL
  • 302,000 MILES
I have replaced all the belts but cannot seem to tension the alternator belt enough. Is there a trick to it i'm missing? I can loosen the belt with the adjustable bolt at the top of it and the bottom pivot bolt, but not enough to tighten. They are v belts not serpentine.
Tuesday, November 3rd, 2020 AT 10:36 AM (Merged)
Unfortunately we don't have a manual on your vehicle because it is not offered here in the USA, but this was a common issue when the V belt was more common. More then likely the belt that you have is just too long. It may be for your engine but there are times when they box the belt wrong or they just made them too long.
So I would remove the belt and stretch it out and measure it then get on that is a few millimeters shorter. Most hardware stores just sell them by length so they should have one that is close. If not, get the one that is the closest but shorter, if that makes sense.
Let me know if you have questions. Thanks
LENNY1163
  • 2003 HOLDEN RODEO
  • 28,000 MILES
The lower belt continually squeals and needs tightening.
Tuesday, November 3rd, 2020 AT 10:38 AM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,878 POSTS
You will need to tighten the alternator slider and the idler pulley. Here is a guide and some diagrams to help you get the job done.
https://www.2carpros.com/diagrams/isuzu/rodeo/2003
Please let us know what happens so it will help others.
Cheers, Ken
1985NISSAN
Mine had a bad bearing, so I always had to mess with it until I had it replaced
RJKENNEDY
  • 2003 HOLDEN RODEO
  • 3.0L
  • 4 CYL
  • 4WD
  • MANUAL
  • 490,000 MILES
How to take off the belt? Can't see where there's a tensioner for it.
STEVE W.
  • 12,961 POSTS
Take a look at the alternator mount. I believe it uses that as the tensioning point for the inner belt. For the AC and PS belts look under the thermostat housing for a tensioning bolt that is horizontal and moves the pump.
RJKENNEDY
Yeah cheers mate, all good now. Got it off. What's the best way to tightening belt up?Feels a little loose, after I put new belt on.
STEVE W.
  • 12,961 POSTS
Run it a couple days, then re-tension until you get about 10-15 mm of movement when pushing on the longest section of belt between pulleys. Then run it some more and check it again, some belts will stretch a bit so they need to be checked, other will tighten up and stay there.
RJKENNEDY
Righto, cheers mate. I give it go, appreciate the advice bud.
STEVE W.
  • 12,961 POSTS
You are welcome. Please return anytime with your automotive questions.
2CP-ARCHIVES
  • 4,542 POSTS
  • 2002 HOLDEN RODEO
  • 170 MILES
Got a squeel coming from engine bay, I think its either a loose fan belt or worn fan belt, however the fan belt tension doesnt seem to bad.I thought it could be a bearing (clutch) also because some times it will be squealing whilst accelerating and when I put the clutch in it stops making the noise but on other occasions it squeals even with the clutch in so not really sure, I dont have a workshop manual so I dont know what the tension should be on the fan belt. It makes the noise randomly and has been doing it more frequently over the last 2000kms. More prone to do it if it rains or has rained which leads me back to the fan belts but not 100% sure?
IMPALASS
  • 3,112 POSTS
Hello - we don't have manuals for your vehicle. However, the best thing is to remove the belt and check all pulley's for free rotation or ANY signs/sounds of worn bearings.
Also, a tensioner can look fine but there is a tremendous amount of stress on them. Most are two bolts off/on and worth the change. Also, when was the last time you changed your belt? Belts stretch and it could be just stretched enough the tensioner can't keep enough on it.
Before sepertine belts normal play was less than to 1/2" press down pressure in the middle of the longest span. As you see by the pic, the arrows indicate where you would push and some have adjusting bolts to take up any slack as shown by the pic
GREGPUG
  • 1995 HOLDEN RODEO
  • 190,000 MILES
I want to change the 3 belts on a Holden Rodeo 2.6 L 1995 petrol Ute & was wondering how to remove fan to allow access to replace the belts. Thank you
KHLOW2008
  • 41,815 POSTS
The fan should be bolted on either with 3 or 4 bolts/nuts. You would have to loosen these to get the fan out. Normally the fan need not be removed for belt replacement. You maneuver the belts over it.
https://www.2carpros.com/diagrams/isuzu/rodeo/1995
What you need to do is to get the belts loose by releasing the adjusting points(adjusters) and tugging at the belt.
JASSO52
  • 1990 HOLDEN RODEO
  • 300,000 MILES
1990 holden rodeo mdi 2.6 ltr
is the water pump connected to the timing chainr or belt? Or the fan belt in this car?
Need to replace waterpump
Thankyou
BILLYMAC
  • 2,204 POSTS
Water pump is ran by the timeing belt
JASSO52
Thanks heaps! BILLYMAC you are a genuis! THE BEST!
BILLYMAC
  • 2,204 POSTS
You are welcome
