Almost stalls
STEPHEN TRUE
  • 1999 SATURN SL1
  • 1.9L
  • 4 CYL
  • FWD
  • 200,000 MILES
The car almost stall when the outside temperature is above ninety degrees. The engine temperature is normal.
Do you
have the same problem?
Thursday, June 15th, 2017 AT 6:39 PM
HEYMAN1104
  • EXPERT
Are there any codes? Having had one of these cars before, I remember having an issue with the intake air temperature sensor causing the car to run roughly, occasionally stall, and shift hard. Replaced it and that took care of it. It is in the image below.
Otherwise, take a good look at your vacuum lines and spark plug wires. Wear and tear on either can cause rough running and stalling.
Let us know.
Thursday, June 15th, 2017 AT 8:01 PM
Recommended Guides
