96 Civic EX Coupe high idle after high speeds
JELLED21
  • 1996 ALL OTHER MAKES ALL OTHER MODELS
Ok, here is my problem, I noticed it the other day. I got off the highway after driving some 10 miles and when I pushed in the clutch to stop the rpm's dropped to idle then rose up to around 1600 then back down, etc. What could make the car do that. It has sat for about 2 years and I got everything fixed. It is a d16y8 SOHC V-tec 4 cylinder. I put on an MSD internal coil eliminator cap with a Blaster 2 external coil. I work on cars for a living so I am pretty sure that my timing might be a little off. I have had the car since 65,000 miles and it now is 128,000. Could it be a TPS (Throttle Position Sensor) or what? It doesn't do it if I just cruise and be nice to the car, but when I drive hard or go on the highway it does it. Any suggestions would be great
Do you
have the same problem?
Monday, January 30th, 2006 AT 12:04 PM
JACK42
Idle control valve
Monday, February 13th, 2006 AT 5:05 PM
Recommended Guides
