1994 XJ Check engine light, runs rough
JEEPGUY2
  • 1994 ALL OTHER MAKES ALL OTHER MODELS
My buddy has a 1994 XJ with a 4.0L engine,
I have tried to get the codes from the pcm by
cycling the key. I think it a 13 which is little or no
change in MAP sensor signal between key on engine off, and idle. Would a bad Map cause the engine to
not start or Idle extremly rough,
any Ideas?
Do you
have the same problem?
Monday, November 27th, 2006 AT 4:54 PM
DAVE H
  • EXPERT
Yes. Replace the MAP sensor
Wednesday, January 6th, 2010 AT 4:53 AM
Recommended Guides
