1988 F-150 4.9L I-6 hazard flasher
BAREFOOTBOB88
  • 1988 ALL OTHER MAKES ALL OTHER MODELS
I would like to know if there is a hazard flasher and a turn signal flasher or are the both combined in one. My hazard lights haven't worked since I had the truck and I finally remembered I need to get a flasher. The parts store told me that I should only have one. I replaced the one on the fuse panel under the dash and it didn't do the trick. I don't think its the switch because when I press the brake with the hazard switch on the front turn signal lamps and the brake lights come on as the would if the flasher was working. So I'm beggining to think that there is another flasher. If so. Where could I find it? Help would be greatly appreciated. Thanks.
Do you
have the same problem?
Tuesday, May 15th, 2007 AT 6:48 PM
SERVICE WRITER
  • EXPERT
Look behing the glove box for the hazard flasher.
Wednesday, May 16th, 2007 AT 9:49 PM
Recommended Guides
