I changed the left blend door (bottom center actuator) now the compressor will not run. I can trip the clutch relay and it runs and gets cold. The refrigerant press s/w shows 1.3 volts the accumulator press s/w is made. There is no ground signal to clutch relay.
The vents have warm air once the engine warms up. A/C is charged. It use to blow cold until the left blend door would act up, then turning the ignition off and on would reset it. I have done the fuse remove reset. No change.
Friday, December 18th, 2020 AT 9:40 AM
(Merged)
