Airbag light is on
VWILLIAM
  • 2004 SUZUKI XL7
My airbag light is on I'm not sure what to do?
Wednesday, October 21st, 2009 AT 7:51 PM
DAVE H
  • 13,383 POSTS
Nine times out of ten its the clocksrping behind the steering wheel that needs to be replaced. Here is a guide that will walk you through the steps and a video below to help run the codes to confirm the issue.
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Scan air code video
https://youtu.be/gnSGfEqrf_w
Please let us know what you find.
Tuesday, April 27th, 2010 AT 4:39 AM
POPPOPWILKIE
You cannot set your clock while you airbag light is on. You need to get your computer reset. The problem is the passenger side seat the sensors are not working right on the bottom of the seat. First check and make sure the wires under the seat are plugged in, I had the same trouble, good luck.
Friday, August 13th, 2010 AT 6:04 PM
LCASHLEY
I had this problem had to do the clock spring cost me $121.00 for the part FYI.
Thursday, January 24th, 2019 AT 2:39 PM
MAX777
  • 2004 SUZUKI XL7
  • 2.7L
  • 6 CYL
  • 147,000 MILES
Air bag light is on, clock is blinking what do I do? Does any body have part numbers for the parts I need to order? Are suzuki xl7 parts enterchangeable?
Thursday, January 24th, 2019 AT 2:39 PM (Merged)
STEVE W.
  • 12,935 POSTS
You need to get it scanned for the codes that are setting off the airbag light. Without knowing what the problem is you won't know how to repair it.
Clock blinking could be related or could be a different problem. Depends on what else that display is used for.
MAX777
Thank you will do
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,787 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
UMAIRAMIN
  • 2004 SUZUKI XL7
  • 117,000 MILES
Helo I have suzuki xl7 2004 model suv I am having problem with air bag light come on and clock is blinking when I check this car through computer its giving code for air bag B1019 vehicle was little accident right side but slightly but that time light not coming but after one year when my friend seated light comes one his weight almost 135 kg so please give me right answer what can I do for this
Thanks
Thursday, January 24th, 2019 AT 2:40 PM (Merged)
HMAC300
  • 48,601 POSTS
You need a scan tool to check this to see if it's recent or not. But you also needa load tool to test it. It may need a new air bag for passenger side. So you should have apro do this.
JUTEDAMA
  • 2002 SUZUKI XL7
  • 6 CYL
  • 96,000 MILES
I have Suzuki XL7 2002 the air bag light went on and the same time the horn dosent work
  • 31,938 POSTS
You will have to get a scan done to see what the set fault code is for the SRS problem, do that first and report the code here for further assistance.
Mark (mhpautos)
WRENCHTECH
  • 20,757 POSTS
Those symptoms are a pretty good indication of a bad Clockspring in the steering column.
https://www.2carpros.com/images/external/97567311.gif
OHANAMOTORS
  • 2005 SUZUKI XL7
  • 6 CYL
  • 50,000 MILES
Does the warranty cover fixing airbag light on and clock blinking constantly?
DAVE H
  • 13,383 POSTS
It depends on the type of warrenty you have?
MOM17025
Happened to our 2004 in 2011, and dealer wanted to sell us a replacement seat for $1700. A call to Suzuki-America and they called the dealer to tell them to reset the circuit. It worked perfectly, suggest you contact dealer and if they refuse, contact Suzuki-US. They were great.
KJC333
  • 2002 SUZUKI XL7
  • 6 CYL
  • 4WD
  • 91,000 MILES
Enter your question.2002 suzuki xl7 horn inop air bag light onclock spring or entire turn signal cruise assy?
KHLOW2008
  • 41,815 POSTS
Should be a faulty spiral reel under the steering wheel.
