2003 Acura TL missfire code
JOSHUA SIMMONS
  • 2003 ACURA TL
Computer problem
2003 Acura TL 6 cyl Front Wheel Drive
The engine light is on and so is the traction control light. It is running rough and throwing a misfire code. The spark plugs were changed and it is still having problems. If I could get some advice on what to do next I would appreciate it. Thanks for your time.
Do you
have the same problem?
Monday, November 2nd, 2009 AT 10:22 AM
HONDA TECH 1818
  • EXPERT
It could be one of the ignition coil are bad.
Monday, November 2nd, 2009 AT 12:35 PM
Recommended Guides
