Car will not start
WRENCHTECH
  • 20,757 POSTS
It has failed something there.
Thursday, January 26th, 2017 AT 6:26 PM (Merged)
CARADIODOC
  • 33,727 POSTS
Timing belt jumped a few teeth or was not put on properly.
SWAYC09
  • 1995 ACURA INTEGRA
Four cylinder front wheel drive manual
well I recently was driving on the freeway and my car start to jerk and somewhat stall and then shut off. It would not start so I had it towed to my house. The next day I went out and took off the distributor and put it back on and it started right up, but when I go to 2000 rpm it bogs and shuts off and will not start. So I repeat the process and take off the distributor and put it back on and it does the same thing. I replaced the distributor cap and rotor, but no luck.
  • 31,938 POSTS
Hi there, I would be checking the plugs and leads and coil. Also, check fuel pressure and get a scan done to check for any unresolved fault codes. Start here.
Mark (mhpautos)
SWAYC09
Well I replaced the spark plugs and wires on Thursday and when I put the distributor on I cannot tighten the bottom screw or the car shuts off and will not start.
  • 31,938 POSTS
Hi there, I can only think that there is a problem with in the distributor, and when a good earth is made when the distributor is tightened up it is causing a short. I would be checking the distributor next.
Mark (mhpautos)
SWAYC09
I cleanrf the spring and the inside where the spring sits on the igniter coil and it is all good now.
Thanks
  • 31,938 POSTS
Hi there, okay, that is good news. Thank you for using 2carpros.
Mark (mhpautos)
KMULLEN8
  • 4 CYL
  • 184,000 MILES
Four cylinder front wheel drive automatic 184,000 miles
car will not start in the morning when it has been really cold outside the night before. When you turn the key, all you hear is a clicking sound.
  • 31,938 POSTS
Hi there,
Start with checking the battery with a load test, this will give a true indication as to the condition of the battery. Check all terminals are clean and tight. Check for twelve volts at starter solenoid when key is on crank, if okay check for faulty starter.
Mark (mhpautos)
LAKEYDEVIN
  • 0.8L
  • V8
  • 121,624 MILES
My fuel pump is pumping, but it will not start. Please tell me what is going on?
CARADIODOC
  • 33,727 POSTS
That is what I should be asking you. Have you checked for spark? Timing? Compression? Diagnostic fault codes?
By "not start", do you mean the starter does not crank the engine, or it cranks the engine but it will not run?
MARTY408
  • 4 CYL
  • FWD
  • 15,500 MILES
Four cylinder front wheel drive automatic 155,000 miles
My car does not start right away in the morning, you can hear the click. The car lights turn on I know it is not the battery.
F4I_GUY
  • 3,302 POSTS
Sounds like the starter motor. Have it tested. Also, ensure that all your power and ground connections are corrosion free.
  • 0 POST
  • 160,000 MILES
When car is started it will not move when in gear or stall when I let the clutch go like it is not in any gear and if it is turned off It will not start, like it has dead battery.
KHLOW2008
  • 41,815 POSTS
The clutch is bad and the "neutral start switch" (on clutch pedal support) needs attention.
ACURALOVER95
  • 4 CYL
  • FWD
  • MANUAL
  • 160,000 MILES
Four cylinder front wheel drive manual 160,000 miles
The fuse keeps going off and the car does not start.
KHLOW2008
  • 41,815 POSTS
Hi acuralover95,
I would like you to indicate to me which fuse is blowing from the two diagrams below and the rated ampere.
https://www.2carpros.com/forum/automotive_pictures/192750_FuseBoxHood95Integra_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_FuseBoxDash95Integra_1.jpg
