1999 Acura CL Oil leaking into coolant
JANDSMARQ
  • 1999 ACURA CL
Engine Mechanical problem
1999 Acura CL 4 cyl Manual
We took the head off, had it pressure tested, replaced all the gaskets, & flushed the radiator, but oil is still leaking in the coolant. Any ideas of what to look for?
Do you
have the same problem?
Wednesday, May 27th, 2009 AT 9:14 PM
Could be the block or intake manifold leak
Wednesday, May 27th, 2009 AT 9:26 PM
Recommended Guides
