1999 Acura CL catalytic converter
CARLOS1982
  • 1999 ACURA CL
1999 Acura CL 4 cyl Front Wheel Drive Automatic
I check my catalytic converter and I need a new one but my question is can the catalytic converter when it get hot can it make the car up a lil.
Do you
have the same problem?
Wednesday, October 8th, 2008 AT 3:35 PM
IMPALASS
  • EXPERT
Hello, not really understanding the question as it reads. Are you asking if it gets hot can it mess the car up? If this is your question, yes, over time depending on how hot it gets, yes. Also, you have an oxygen sensor right behind the CAT. If it is getting really hot it can transfer to the O2 sensor and mess it up. Then you will be having O2 sensor problems too. Hope this helps.
Saturday, October 11th, 2008 AT 12:20 AM
Recommended Guides
