A/C not working
MRSSUHGAFOOT
  • 2000 MERCURY MARQUIS
  • 251,000 MILES
My heater will blow and works good, but when I turn on my A/C it will not work. Will not blow air or do any thing.I have change the control system on dash it worked for a few min then stopped. I was told that it could be some door not switching over so that is why the A/C is not coming on. I need my A/C really bad because it gets very hot in Texas and I have leather seats.
Do you
have the same problem?
Monday, May 13th, 2013 AT 9:19 AM
CADIEMAN
Find the blower motor under the power wire follow it to a module mounted in the upper AC case. This is the AC power module you will need to replace this. Thanks
Monday, May 13th, 2013 AT 9:36 AM
