ABS problem
HAMEDSTAR
  • 2006 HOLDEN COMMODORE
  • 3.6L
  • V6
  • 4WD
  • 177,090 MILES
I had a GSCAN it showed the following error codes and messages:
U0121 Lost Communication With Anti-Lock Brake.
U0415 Invalid data received - anti-lock brake system.
P0850 Park/Neutral Switch Input Circuit.
Note : The car starts to slow down after the brake pedal is pressed halfway
Could you please help me?
Thank you
Do you
have the same problem?
Saturday, November 23rd, 2019 AT 10:24 AM
JONNYB1963
  • EXPERT
Hi and thanks for stopping in to see us.
The First code U0121 Lost Communication With Anti-Lock Brake. is something I see often where there are other things going on and system is "busy" dealing with other trouble codes. Other times I see it when the ABS system has truly lost communications all together (its rare but it does happen) .
The second code, U0415 Invalid data received - anti-lock brake system is also something I see often and could be related to something else being wrong and in itself just a symptom.
The third code you gave "P0850 Park/Neutral Switch Input Circuit" is the one I would tackle first before sweating too much about the ABS codes.
The P0850 Code means that the Power-train Control Module (PCM) is confused about the state of the transmission. It is not able to tell if the transmission is in park, neutral or in gear. Typically this is caused by a faulty neutral safety switch.
See the link below:
https://www.2carpros.com/articles/how-a-neutral-safety-switch-works
Fixing something like this is very inexpensive and can take you about 15 to 20 minutes to do.
Regards
Jon
Tuesday, November 26th, 2019 AT 5:21 AM
HAMEDSTAR
Thanks Mr. Jon.
Friday, December 27th, 2019 AT 12:28 PM
KEN
  • ADMIN
Monday, December 30th, 2019 AT 5:50 PM
