ABS light
CRUZERB4
  • 2000 GMC SIERRA
  • 5.3L
  • V8
  • 4WD
  • 153,000 MILES
How many (ABS) frame ground points?
Do you
have the same problem?
Wednesday, May 15th, 2019 AT 5:21 AM
CARADIODOC
  • EXPERT
That's not the question pertinent to this problem. Have you had the diagnostic fault codes read? If not, that is the place to start. Post the exact code number in your reply, then I'll look up the definition for you. You will likely need to visit a mechanic to have the codes read. People at many auto parts stores will read codes for you for free, and you can try that, but most of them can only read codes in the Engine Computer.
Previous to this, have you noticed any instances of "false activation", meaning the ABS kicks in at low speeds when it isn't needed?
Wednesday, May 15th, 2019 AT 9:17 AM
Recommended Guides
