VSC light on?
SAL GIOE
  • 2008 SCION XB
  • 2.4L
  • 4 CYL
  • 287,000 MILES
I got a co2 upstream code. I replaced it but the lights still wont go off. I tried disconnecting the battery but the light comes on again. Will the lights go off with driving?
Friday, August 30th, 2019 AT 6:09 AM
  • 52,797 POSTS
Good morning,
It sounds like you have a wheel speed sensor that is not working correctly but to be sure let follow this video on how to get the codes to help tell us which sensor is out.
https://youtu.be/rTtAnsOlZU4
Here are the instructions below to show you how to change out the wheel speed sensor. Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Friday, August 30th, 2019 AT 6:37 AM
DOCKK
  • 2008 SCION XB
  • 5,200 MILES
I was in a rear end accident and all the lights abs brake and tc wont go off the insurance company is telling me that they won't cover the damage because they said they dont feel it is related to the accident but none of the lights were on before the accident I was wondering how I can prove that they were caused by the accident.
Monday, September 28th, 2020 AT 12:37 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Retrieve the trouble code and let us know what they are.
DOCKK
As soon as I get them thanks
KHLOW2008
  • 41,815 POSTS
The trouble code would tell us what is causing the lights to come on and from there we would understand if it is related to the accident or repairs carried out.
Btw has repairs been done?
JOSEPH SILVA
  • 2008 SCION XB
  • 150,000 MILES
My brakes are hard to push on, I changed brakes and rotors. I took it to my mechanic says it’s a front speed sensor but I wanted to check with anyone could it be anything else.
PS: trac light is on.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
You will need to have the trac light code read.It means a code is stored in your vehicles computer.Here is a tutorial showing what is involved reading codes:
If you don't have access to a code reader/scanner most auto parts will read them for free or have a tool loaner program and can rent you one. After you retrieve the code get back to us with the code number and we can properly diagnose the problem.Hope this helps and thanks for using 2CarPros.
Danny-
