ABS and brake light
DANHANSEN233
  • 2006 CHEVROLET SILVERADO
  • 5.7L
  • V8
  • 4WD
  • 140 MILES
ABS and brake light comes on at start up, no codes found, clear light with scan tool, lights stay off until key is cycled, then they come back on. No codes found? Drive cycle test shows all wheel speed sensors working.
Do you
have the same problem?
Monday, October 15th, 2018 AT 6:48 AM
KEN
  • ADMIN
This can happen if the brake fluid level is low. Can you check it please? Let me know, Cheers, Ken
Tuesday, October 16th, 2018 AT 11:10 AM
DANHANSEN233
The brake fluid level is fine, my son just purchased the truck. The lights were on when he got it. We installed new pads and rotors for and after.
Tuesday, October 16th, 2018 AT 11:38 AM
DANHANSEN233
That is Forward and AFT.
Wednesday, October 17th, 2018 AT 4:09 AM
KEN
  • ADMIN
If the fluid level is okay and the fuses are good then the module must be bad. Here are videos on how to double check for codes and how to change the module out. Also, lets check the fuses before you begin.
ABS scan:
https://youtu.be/rTtAnsOlZU4
ABS Module:
https://youtu.be/lUotkKXG9dY
And how to check a fuse:
Look at the ABS wiring diagrams to see how the system works and which fuses to check.
Here are the instructions on how to change the ABS module out (below).
Wednesday, October 17th, 2018 AT 9:29 AM
Recommended Guides
