A/C Problem on '94 Ford F-150
JTSTOREY13
  • 1994 FORD F-150
  • 4.6L
  • 6 CYL
  • 160,000 MILES
So recently I just fixed my a/c to blow out cold air and a day later, the air does not blow out the regular vents, it blows out the defroster vents. I need to know how to fix it.
Do you
have the same problem?
Sunday, April 6th, 2014 AT 2:51 PM
CARADIODOC
  • EXPERT
If you have vacuum-operated mode doors, look for a break in the vacuum hose feeding that system. Typically it's a small hard plastic hose running from a tee on the firewall to a small check valve, and from that, through the firewall. Most systems are designed to default to the defrost vents for safety. Your feet might freeze but your windshield will be clear.
Sunday, April 6th, 2014 AT 7:47 PM
Recommended Guides
