Low Compression?
ATHEE
  • 2006 FORD RANGER
  • 6 CYL
  • 95,000 MILES
Hello Guys,
Here's the deal. I have a 2006 Ford Ranger purchased in March 2008 with 10K miles. I use it for pilot car/escort business. I now have 97K miles. Recently my check engine light came on. Engine codes showed low compression in cylinders 4 and 5. After new plugs and coil, the light still remains on. I recently took vehicle to another mechanic and after a compression check said cylinders four and five were lower than others. My truck actually runs really well; however after engines is warm it idles very rough and engine light flashes. After 1000 RPMs it smoothes on out. I have not experienced any loss of power while on the road which is quite a bit. The mechanic did some research and found where there may be some faulty valves involved. The repairs are estimated at $1500.00 Another estimate is $1200.00. I don't mind paying, I just want an honest repair. My truck is my lifeline and I have done all maintenance religiously.
Saturday, February 28th, 2009 AT 11:08 PM
MHPAUTOS
  • 31,938 POSTS
Hi there,
to diagnose this correctly, you can have a wet & dry comp test done or a leak down test, the wet & dry will show up any valve leaking as a wet comp test is where you add a small amount of oil to each cyl , this temporally seals the rings and if the comps stay low the leak is in the valves, a leak down test is where air is pumped into the cylinders and if thee is a leak from a valve you will hear it in the exhaust or inlet port.
These guides will help us fix it
https://www.2carpros.com/articles/the-reasons-for-low-compression
and
https://www.2carpros.com/articles/symptoms-of-low-compression
Saturday, February 28th, 2009 AT 11:26 PM
ATHEE
Thanks for getting back. This has been going on for about six weeks. Is it ok to continue driving or will it get progressively worse.
Athee
Sunday, March 1st, 2009 AT 9:27 AM
HELPING YOU
  • 100 POSTS
Hi, I'd request a "fuel injector relative flow" test also, - just to rule out - excess fuel could've washed cylinder walls causing low comp in two.
Sunday, March 1st, 2009 AT 9:39 AM
MHPAUTOS
  • 31,938 POSTS
Hi there,
I would get this looked at ASAP as it will deteriorate and it may get to the point that I will let you down and cost more to repair.
Mark (mhpautos)
Sunday, March 1st, 2009 AT 3:11 PM
NCEAGLE7
Is this a common problem with this model year? I have a 2006 Ford Ranger that I bought in 07 when it had 20,000 miles on it. It currently has 94,800 miles on it. It recently started Idling very rough and set off the check engine light. The truck runs fine once you step on the gas. I took it to a Ford Dealership today and they told me that there is low compression in cylinder 4. They told me that they would have to take the engine apart to find out what is causing the problem and even then wouldn't guarantee that they could fix the problem. Can anyone give me recommendations and tell me if this is a common issue with this vehicle?
Wednesday, February 8th, 2012 AT 2:08 AM
RIVERMIKERAT
  • 6,110 POSTS
Nceagle, do the wet and dry compression tests. Put about a teaspoon of engine oil in the spark plug hole and do the compression test. If the causes the compression to pop up, you have bad rings. If not, valves.
One reason I like working on cars is that you can fix anything with enough money. The dealership lied to you. Valves and rings can be fixed relatively easily by any mechanic worth his tools. They're both labor intensive jobs, so they aren't terribly cheap.
YOU can do all of the re-ringing yourself with a motor repair manual. You can also do MOST of the valve job yourself with a manual. You'll just need to take the head to a machine shop to have the new seats installed and cut.
Thursday, February 9th, 2012 AT 7:06 AM
DANNY MCGOWAN
  • 2005 FORD RANGER
  • 3.0L
  • 6 CYL
  • 180,000 MILES
I have the vehicle listed above Edge. When idle for extended period loses compression and the engine will putter at snails pace on takeoff. Once it rebuilds compression it will take off and bounce your head off the seat. Runs awesome on open road no problems. Was told by mechanic at 79,000 miles that cylinder five had very little compression. Was quoted $1,500.00 to $2,000.00 to attempt fix. I didn’t and it now has 180,000 miles. I am going to sell this truck so I thought maybe I’d finally fix it. :) Doesn’t smoke or use oil. Any help appreciated.
Wednesday, July 29th, 2020 AT 10:47 AM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
This could be from a few different things. My guess without having the truck right here in front of me to inspect would be a blown head gasket, but it could be a bent valve, worn out piston rings, or a burnt valve. I have included a couple of links down below for you to go to:
https://www.2carpros.com/articles/head-gasket-blown-test
Please go through these guides and get back to us with what you are able to find out. Once we get the problem narrowed down we will have specific instructions on how to fix it.
Thanks,
Alex
2CarPros
DAN STEWART
  • 2002 FORD RANGER
  • 6 CYL
  • 4WD
  • 12,100 MILES
The Check Engine Light Was Blinking last night and it was tough climbing hills. Today running real rough. Dropped it off at a Ford dealer. They say they're going to have to tear the engine apart to find the problem. It has low compression.
What does this sound like? Anything else I could check?
SERVICE WRITER
  • 9,123 POSTS
Typically the cel blinks when too much raw fuel is entering the combustion chamber and not being burned. If too much fuel had got into the cylinders it may have washer down the cylinders causeing the low compression and rough running.
I would start by pulling codes. I would shoot a litttle oil into each cylinder and see if the compresion returns. Oil probably smells pretty gassy.
GFOLEY
  • 2001 FORD RANGER
  • 4.6L
  • 6 CYL
  • 70,000 MILES
Low compression in 3 cylinders.
STEVE W.
  • 12,963 POSTS
Welcome to 2CarPros. Is the low compression all on one bank or is it split across them?
The 4.0 V6 has a nasty habit of breaking the timing chain guides and the chain get's loose and slips. They have been updated in the newer engines. They are not a fun engine to work on as they have one timing chain at each end of the engine with a jackshaft in the middle of the block that has another chain for a total of 3 timing chains. These are an interference engine as well so if any of the three chains fail while the engine is running you get valve damage.
The easiest way to verify this is to remove the valve-cam covers to see if the cams are moving.
Wednesday, July 29th, 2020 AT 10:48 AM (Merged)
NONBLONDE
  • 2000 FORD RANGER
  • MANUAL
Can a compression test be done if engine will not turn? Car will not start. Mechanic wants to tow car to his workshop and have compression checked. All parts under bonnet have been replaced over the past 12months so mechanically its a new car, no worn parts.
DOCFIXIT
  • 18,828 POSTS
If engine cranks then compression can be done. Have you checked for spark and fuel?
NONBLONDE
Engine is not cranking and we have done all usual checks ie sparks. Had a new engine in mid 2010.
. Oringally we though it could be fuel pump but mechanic wants to tow to his workshop
to check compression.
If it was compression would a steep hill start get it going. We have only tried a level road.
Any ideas?
BIRONWILLFORD
  • 8 POSTS
  • 1992 FORD RANGER
  • 170 MILES
I have a 1992 ford ranger distributorless ignition 8 plug 4 cylinder I have installed the head from a 95 head the old head was ruin I have tried timing marks for the 92cam and 95 cam neither has worked plenty of fire plenty of fuel will only spin have even tried swapping cam sprocket no luck witch marks should I use the inner timing cover cam alignment differs between both engines even when I swapped sprockets the timing marks differ by about 30 degre
KHLOW2008
  • 41,815 POSTS
Since you are using the 95 head and cam, you should be using the timing for this engine.
If you are not able to get the correct timing, turn the # 1 piston to TDC and then use the valve overlapping method for cylinder # 4 to get the correct valve timing and compare with the marks.
CJ MEDEVAC
  • 11,004 POSTS
No problem
2 people---will not take long--evil female in you house will do!
Disconnect the coil so it cannot start
take out #1 spark plug
watch out for the fan!
Stick your finger/ thumb in the empty hole tightly!
Evil woman "bumps" the motoror turn it in the correct direction with a wrench
(regardless, it will build compression, bumping with the key, sometimes lets the engine "roll or kick back" when the key is released. Sometimes using a wrench is better)
this is a 4 cycle engine--the crank rotates 2 times (piston up 2 times)for every one time it makes a cycle
one is exhaust stroke (pushing toward the top)
the other is compression stroke--this is the one we want!
This is the only upward stroke that both valves are closed and air/ fuel pressure builds up--when it reaches the top, this is top dead center (tdc)
so here's the deal--when she bumps it and you get a "spit of air" by your thumb----stop stop stop! (You may want to practice a time or two, we want the beginning of the spit--not after you pass it!)
you are headed up, on compression!---Beginning of the spit
now you must turn the engine by hand, in the same direction it normally turns---using a socket on the harmonic balancer nut and a ratchet/ pull bar/ pull handle
turn it slowly until your timing marks line up on "zero"
this is tdc!
This is my jeep cj 5 6 cylinder (258) on 8 degrees before tdc (btdc) and the next pic is tdc (zero) yours is different!
Remember this happens twice in a cycle (timing marks line up)--only once for the compression stroke. Compression will not build until both intake and exhaust valves are closed
with your modifications---if the cam(s) ain't timed to their correct open/ closed positions for "tdc"---this "old time method" just ain't gonna work!
The medic
KHLOW2008
  • 41,815 POSTS
No problem. It is always good to have a second opinion. :)
DUSTIN2551
  • FORD RANGER
I have a 1984 2.0 liter Ford Ranger with 135,000 miles. When I go up hills in 4th gear it drastically slows down till I get to the top. If I keep it in 3rd I can make it up just fine. Plus i'm getting horrible gas mileage right now its around 13 miles per gallon. I've replaced the plugs, plug wires, fuel filter, air filter, distributor cap, distributor rotor, and fixed all of my vacuum lines (some weren't even connected). I have also ran sea foam through the fuel system. Do I need a new carburetor?
