There is nothing more worrying than hearing unusual noises coming from your car. One such noise is the squeaking sound that can occur when you are turning. This comprehensive guide will walk you through the steps to diagnose and fix this issue.
Squeaking noises during turns can come from several places, including the steering system, the suspension, or the tires. Pay close attention to the noise and when it happens to help identify its source.
If the squeak is not originating from the steering system, it may be coming from the suspension. Here's how you can inspect it:
Lastly, don't forget to check the tires. Improperly inflated, misaligned, or worn-out tires can cause squeaking noises when turning.
Once you've identified the source of the squeak, you can take the necessary steps to fix it. This might involve replacing parts, lubricating components, or simply inflating your tires properly. If you're not comfortable doing these tasks yourself, take your vehicle to a professional mechanic.
A squeaking noise when turning can be a symptom of several different issues with your vehicle. By following this guide, you can identify the source of the problem and take steps to resolve it. However, if you're uncertain about any part of this process, it's always best to consult a professional mechanic to ensure your vehicle's safety and performance.
