Engine will crank but will not start up?
2001 CHEVROLET MALIBU
218,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
LOSSPREVENTOR
I have replaced the starter after it failed and then the alternator and then all cool packs and wires. The car started running real rough and now will not start at all. The code reads multiple misfires and that is it. I hooked up a fuel pressure gauge which read 0 so there was no fuel going to the fuel rail. The fuel pump is humming when the key is turned to the on position so it is working. The theft light is not on on the dash. Can you think of any reason why the car will not start or have had getting to the fuel rail? Any help would be great I have already put more money than it is worth for nothing because it still will not start. Please help
Nov 13, 2017 at 8:26 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
This sounds like a fuel pump or the crankshaft angle sensor has gone out. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Nov 14, 2017 at 7:02 PM
STEVE W.
  • 15,157 POSTS
There is the hose from the pump to the exterior of the pump module that cracks inside the tank. Pump runs but no pressure because it is spraying into the tank.
Nov 15, 2017 at 8:02 PM
MALO
Chevy Malibu won't start. Acts like it is not getting fuel. Doesn't even partially fire. The battery turns over great, but acts like it's not getting any fuel.
This is a first time event. We tried letting it sit for 20 min. but got the same results. Can you help?
Thanks,
Matt
Jan 27, 2021 at 5:54 PM (Merged)
JDL
  • 16,098 POSTS
When you turn the key on, no crank, is the theft lite flashing? If it is, wait and see if the lite goes off, then try to start.
THEWORMINATOR
Just had this problem with my 2000 malibu. I was driving home and the car just shut off and acted like it was out of gas. I had to replace the fuel pump. had this problem before and was able to fix it with replacing the fuel filter this time however replacing the fuel filter didn't work and I had to pay a mechanic. hope this helps.
TOMSHANTY
  • 34 POSTS
This has happened twice with similar symptoms.
The first time this happened, I checked the fuel pump relay and found some white corrosion. When I replaced the relay, it started right up.
The second time this happened, I checked the fuel pump relay and found the same corrosion. When I replace the relay again, it did not start. And I can hear the fuel pump turn on when I turn on the ignition. I tried replacing the fuel filter and nothing.
Is it possible for the fuel pump to be bad even if I can hear it turn on? Any other ideas? Thanks.
Jan 27, 2021 at 5:56 PM (Merged)
DRCRANKNWRENCH
  • 3,380 POSTS
Yes the pump can be bad. Test the fuel pressure. You can go to any Advanance Auto or Auto Zone to get the proper test kit which they will loan to you.
WRENCHTECH
  • 20,761 POSTS
Make sure you are testing that fuel pressure DURING THE FAILURE. The test will be useless any other time.
JONATHANBURL
Drove to work yesterday just fine. Went to leave wouldn't start. I come back to tow it and it starts right up and drives home fine. Starts up the next morning and drive to work fine. Go to leave again and won't start. Can hear the fuel pump turn on. Don't know where to go from there
Jan 27, 2021 at 5:57 PM (Merged)
JDL
  • 16,098 POSTS
Maybe an intermittent rpm signal? When the problem occurs, have a helper crank it while you visually check for spark at the spark plugs. If you have spark everywhere, check fuel pressure and injector pulse.
Can you check for applicable trouble codes? Some of the national brand autostores wsill check codes for free. Intermittent issues can be hard to track. Have to test when problem is ongoing.
JOAN KIMMINAU
It has not stalled completely. I think it must be the last tank of gas. What do I do to get the water out of it?
I am a 72 year old woman and have no intention nor any way to work on my own car.
Jan 27, 2021 at 5:59 PM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
The best way to get bad gas out of your vehicle is to drop the tank and drain it. You might be able to get a siphon hose kit from a store like Harbor Freight and siphon the gas out of the tank this way. There are some products at your local auto parts store that are supposed to fix this problem, but I have only heard of limited success at best with these and I don't recommend them. Did you fill your tank when you got gas last? Please get back to us and we can go from there.
Thanks,
Alex
2CarPros
DOM_TARA24
When I go to start the car it turns over, but refuses to start. I have a mechanic, but he said he cant figure out why its doing that. He replaced the crank sensor, but it starts when it wants and stops went it wants.
2CARPRO JACK
  • 11,533 POSTS
Is it losing fuel pressure? or spark? Might need to relearn the Pass-lock key. Turn ign "on" try to start and let key return to "on" wait approx 10 minutes, security light will go out. Turn key off and wait 5 seconds and repeat procedure 2 more times.then start car
DANPERAGINE
Engine Performance problem
2001 Chevy Malibu 6 cyl Front Wheel Drive Automatic
I have been trying to start this car for months, the engines getting spark , getting fuel cranks free, just wont start. the theift system was checked and its not flashing. sounds like a timing problem spray starting fluid in the air cleaner and back fires could the camshaft sensor be bad and how can i test it
BASSTECH
  • 236 POSTS
the best way to check a cam sensor is with a diagnostic tool so you can see what's it's doing while your cranking it. It is also possible that the ignition module is defective. even though your getting spark it could be sparking at the incorrect time. Can you do a compression test on a few of the front cylinders to see if the timing chain is ok ?
DANPERAGINE
[quote:ce3c1307d8="basstech"]the best way to check a cam sensor is with a diagnostic tool so you can see what's it's doing while your cranking it. It is also possible that the ignition module is defective. even though your getting spark it could be sparking at the incorrect time. Can you do a compression test on a few of the front cylinders to see if the timing chain is ok ?[/quote:ce3c1307d8]
I have comperssion in all cylinders and how do I check the ignition module. However when the car overheated just before the rebulld all the dash lights came on and then keept driving then all the lights went off if this has any signifiacnts
BASSTECH
  • 236 POSTS
If you have spark, fuel, and compression...then you either have to little or to much of one of them.
Not sure what you meant by all the lights came on then went off.
You said that it overheated before the rebuild.
Did you rebuild it, or did someone else do it? and how much of it did you rebuild?
Did you just do the head gaskets or did you drop the crankshaft and remove the pistons too?
See if you can get a vacuum gauge on there and see what the cranking vacuum is.
MARKPALMER
Running fine parked overnight next morning turns over but wont fire. changed badly worn plugs and now will start for 3 seconds and shuts off. fuel pump seems to be working. can hear it and gas flows from filter when line disconnected. checked computer codes with an inexpensive scan tool and 2 showed up but were not to car starting or running. theft light not blinking but did the steps to clear it anyhow. any and all suggestions would be great. thanks
Jan 27, 2021 at 6:03 PM (Merged)
  • 110,190 POSTS
Although you hear the fuel pump running, it may not be producing enough pressure to run the engine. I do recommend check it. Since it does start, that is my first suspect.
Here is a link that explains how to test the pump pressure:
Here are the manufacturer's specs for fuel pressure:
2000 Chevrolet Malibu V6-3.1L VIN J
Fuel Pump Pressure
Engine not running 52 -59 psi @ 0 rpm
Check pressure with the key on and the engine not running.
STUDMAN
no scan codes, getting spark,getting fuel , has good comp.checked all fuses and relays. ben driveing good parked it the next day will not start ben trying everything for about two weeks now and nothing. it's a malibu LS model.v-6. real nice car but ready to pull hair out
Jan 27, 2021 at 6:04 PM (Merged)
  • 110,190 POSTS
Hi:
First, don't pull your hair out.
Second, have you actually checked the fuel pump pressure? Will the engine fire with starting fluid?
If you have spark, is it a good hot blue spark?
If you have spark, fuel, and compression, it should run unless it jumped time. When you shut it of the prior night, was everything as normal?
STUDMAN
i didn't put a gauage on the fuel rail to know exzack but from pushing on the valve stem on the rail it seems to have good presure to me.
i tryed to heat-up a copuple plugs in my stove oven and spraying starting fluid in the cyl. and put the plugs back in hot to aid the fireing but nothing.
yes it is a good spark, i even checked a couple
plugs,not just one.
yes eveverything was normal when i shut it off the night before. it was driven all that day with no problem.
just a little footnot, i do and have ben working on cars now for quite a while so i do know quite a bit already. it's just this one got me stumped.
  • 110,190 POSTS
Have you checked to see if the injectors are firing? Even if there is pressure in the rail, the injectors may not be firing.
Is the security light on? if so try the procedure below
https://www.2carpros.com/articles/how-to-reset-a-security-system
  • 110,190 POSTS
Hi:
I'm starting to understand why you are pulling your hair out, and I don't have much left. (LOL) If you have spark, compression, and fuel, the engine should run or at least try to. Like you said, it is possible that the timing is out. Does the engine sound normal when cranking?
STUDMAN
yes the motor sounds normal when it is turned over, it sounds like it just keep cranking with nothing, like it dosen't even try...the only thing that is different which seen odd to me is that if i releave the the fuel presure at the fuel rail by the ues of the valve stem and try it for the first couple of turns it stumbles a little like it's trying then it just keep cranking with nothing no attemp or anything, at other times i releave presure and nothing will happen at all i know it's still getting spark, and there plunty of gas in the tank.
  • 110,190 POSTS
Hi:
It almost sounds like you may be getting too much gas (bad regulator) based on it trying to start after the pressure is released. See if you can find the fuel pump fuse and pull it. See if it will fire for a second or two. Or, you need to check fuel pump pressure.
Let me know which way you want to try it.
STUDMAN
No fuel pump fuse, pulled relay and tried it. Im falling back on timing chain skipped
