Mechanics
WONT START
2002 Chevrolet Blazer • 142,000 miles
Got a 02 blazer 2wd it wont start it turns over. And the batt keeps dying I can hear a light hum from the alt replaced it still the same thing. I have replaced timing chain&gears, plugs, wires, crank sensor, cam sensor, cap rotor, dist, wires. Can hear the fuel pump whe key is turned checked the timing(base) few times. Please help
Tlyons34
May 15, 2013.
Check battery condition including load test then scan for codes and check fuel pressure first.
Hmac300
May 16, 2013.
AD
