Mechanics
WON'T START
1999 Ford F-150 • 22,500 miles
I'm not getting any fire to the spark plugs. I've checked all of the fuses, I looked for any broken, burnt or loose wires and they all seem OK. And I tried more than one key to make sure that wasn't the problem. What else do I need to check or try? Thank you for your help!
Chuck evans
May 6, 2013.
ENGINE SIZE?
THE MEDIC
AD
CJ MEDEVAC
May 6, 2013.
It's a 6 cylinder I put a diagnostic tester on it and the only thing that came up was P0001 fuel pressure regulator open circuit. Is there any place in particular that I should look to try to find that?
Chuck evans
May 13, 2013.
Did you check to see if there is any fuel pressure?
Is there any spark from the distributor while cranking?
ASEMaster6371
May 15, 2013.
U: No there is no spark at all while cranking it. I'm getting fuel to the fuel rail but I don't know what the fuel pressure is. I've changed the fuel pump, filter, and find pressure regulator.
Chuck evans
May 15, 2013.
That should have said fuel pressure regulator.
Chuck evans
May 15, 2013.
AD
