window regulator
2005 FORD F-150
230,000 MILES • 6 CYL • 2WD
PALACIO239
  • 12 POSTS
hello i have a problem with the driver side window, it is a manual crank window, the window will not roll down, i’m wondering if it could be the regulator that needs replacing? is there a diagram for the removal of both the door panel and the window regulator? -thank you-
Dec 18, 2020 at 8:40 PM
