Mechanics
WILL NOT TURN OVER- GOOD BATTERY AND STARTER
1996 Honda Civic • 225,000 miles
We had the battery and starter tested, they're both good. The car will not turn over. When you turn the key you get the dash lights on and the dinging noise that tells you to put on your seat belt. The car does not turn over. How would you know if this is the ignition switch or the clutch switch? Or another possibility? Thanks!
Mebazi
August 31, 2013.
Check to see if there is power both in and out of the clutch switch. Also, check the starter relay.
