Mechanics
WHAT NEEDS TO BE REMOVED TO CHANGE THERMOSTAT HOUSING ON XLT
2001 Ford Explorer • 232,414 miles
My issue is coolant leaking from the thermostat housing. I have a complete thermostat housing (incl. Thermostat). Removing the top portion of the thermostat housing is no problem, but it appears that I will have to remove the manifold to gain access to the screws that secure the lower housing. I would like to know what I can expect to remove to gain access to the entire housing. Are there any additonal gaskets that I will need? Is the only way to to get to the lower housing and have enough clearance is to remove the alternator?
Mrwhyt2
May 6, 2013.
What motor?
4.0 Liter 6 cyl. SOHC
AD
Mrwhyt2
May 8, 2013.
Just remove the alternator it will give you plenty of access for what needs removed. Just make sure you have a new top for the thermostat housing because the one you take off will likely bust cause its brittle and cheap.
Rmb1057
Jul 12, 2013.
AD
