1998 Volvo S90 Repair Question
Topics covered: Engine, Dip stick, Engine seals.
Asked on February 21, 2010
1998 Volvo S90 oil leak
1998 Volvo S90 Automatic 132200 miles
Hi..
I can see smoke coming out of the dip stick area, and after driving, oil is on the engine in this area.
I put a cover in the dip stick hole and 10 seconds after I heard air leaking from another part of the engine, after I put a hose over the dipstick hole that comes out the bottom of the engine and now after I drive the engine stays clean, so oil is leaking out of the dipstick.
who can i fix the leak?
Hi..
Answer
Replied on October 6, 2012
Change the pcv valve. Is cheap and easy.
You need to check the engine seals.
