2000 Volvo S80 Repair Question
Topics covered: Brake caliper, Brake pads, Brakes.
Asked on May 4, 2008
Rear brakes and rotors
Brakes problem
2000 Volvo S80 6 cyl Two Wheel Drive Automatic 85000 miles
I need to change out my rear brake pads and rotors. I was able to remove the brake calipers but had trouble removing the rotors. I saw that there was 3 bolts holding it in-place I believe. Is this correct. Once I remove those bolts the rotors will come off with a little purswation.
Thank you
Mtnman54
Thank you
Mtnman54
