Power locks will only lock not unlock.
JSARNES
  • 2006 VOLVO S60
  • 62,000 MILES
The key fob will lock and unlock the doors, but the button on the inside on the door will only lock the doors. Is this a problem with the power lock module?
Wednesday, December 28th, 2011 AT 4:42 PM
DOCFIXIT
  • 18,828 POSTS
Way to find out is have door lock system diagnosed with a scan tool. System is selfdiagnostic
Wednesday, December 28th, 2011 AT 5:27 PM
JSARNES
Ok. Does this have to be done at the dealership or can another place do this?
Wednesday, December 28th, 2011 AT 5:30 PM
DOCFIXIT
  • 18,828 POSTS
Would recomend dealer they will have equipment. Not likely independent would invest in that type of tool. There are five modules that control door operation so gets a little involved
Wednesday, December 28th, 2011 AT 5:35 PM
JEFF_SP87
  • 2005 VOLVO S60
  • 4 CYL
  • 45,000 MILES
What would make my trunk and door locks just stop working the from door locks still work
Monday, August 26th, 2019 AT 6:45 PM (Merged)
JIS001
  • 3,408 POSTS
The first thing you need to do is check your fuses at the rear electronic control module. It is located in the trunck left side behinde the trunk liner.
JEFF_SP87
It wasnt the fuse they were all good anything else you think it might be thanks jeff
JIS001
  • 3,408 POSTS
I just want to make sure weare on the same page so I am including the wiring diagram and fuse location and what that fuse controls. Grab a test light and check that you have power on both ends of the fuse. Fuse # is 28 and it is the only fuse that controls the rear trunk and rear door locks and it alo controls your fuel door lock. Are yu having problems with that also?
https://www.2carpros.com/forum/automotive_pictures/337695_fuses_1.jpg
See the diagrams below
DTVDICK
  • 2001 VOLVO S60
  • 6 CYL
  • FWD
  • 81,000 MILES
Locking noise from trunk area when unlocking door locks with remote on 2001 Volvo s60
JIS001
  • 3,408 POSTS
Does the trunk lock properly and unlock when you use the remote? The trunk lock mechanism could be failing.
DTVDICK
Sometimes, I have to press the trunk lock two or three times before it will open. So you think it could be the trunk lock? I never thought of that, but I only hear the noise when I am unlocking the doors. Any suggestions.
  • 31,938 POSTS
Check the lock and the adjustment of the slam plate, the lock may be triggering and not unlocking due to an adjustment problem.
Mark (mhpautos)
JIS001
  • 3,408 POSTS
Yes, if you hear the actuator working in the trunk area but it does not unlock, then that could be failing already. Have replaced a few of them because they do go bad sometimes. Especially if it is when unlocking. Next time just use the key in the trunk and see if the lock actuator tries and fights you to lock back or vise versa, you try to lock but then it unlocks? If it does the trunk latch mechanism is faulty. Let me know what you find.
Monday, August 26th, 2019 AT 6:46 PM (Merged)
