Mechanics
'94 TURBO SPEEDOMETER MALFUNCTION
1994 Volvo 940
1994 Volvo 940 Turbo Sedan
According to my daughter, the speedometer simply quit working after she hit a bump in the road. Several miles later the speedometer began working again. Today it quit again and has remained off. I'm curious as to whether this is a simple issue with a loose cable or if it has more to do with the onboard computer. If it sounds to be a cable issue, I'd really appreciate a heads up as to where to locate each contact point, so I can attempt to tighten it myself. If not, any ideas would be helpful.
Thanks in advance,
Lucky
Lucky11
December 31, 2006.
Hi Lucky11 got the same sort of problem, did you get an answer to you question?
Hugzy
Feb 14, 2007.
